Laid out position for canopy roll bar. Drilled the copy deck, then clamped the roll bar in place and match-drilled with long #30 bit. The rear holes turned out to be too close to the roll-bar-attachment weldment joint! Will need to redrill new pilot holes so the full-sized hole for the AN4 bolt encompasses the original milocated pilot holes.
