Brief Description: Installed fuel lines 2nd & last time maybe
Worked the fuel lines from both tanks through the weldments and brackets for the second time. The short hours testify to the ease that the spring bender brought to the job. However, the lines may be a bit on the short side--not quite 6" of free, undamaged tubing sticks out the fuselage sides. If I decide to install fuel filters and pumps in the wing roots, there's likely enough tube. If not...well, third time installing the fuel lines will be the charm.
Torqued up the B-nuts 1/4" turn past finger tight at the selector valve.
