Brief Description: Rivet outboard seat ribs: two more dimples
Riveted the outboard seat ribs to the center fuse section bottom skin. Turns out I didn't dimple the bottom-most hole on the vertical members of the F-705 bulkhead. Had to grind down the nose of the modified C-clamp as well as enlarge the flat on the side of the female dimple die to get the durn holes dimpled.
