Brief Description: F-721 canopy decks and F-757 gussets
Riveted the F-721 canopy decks and F-757 gusset plates to the main longerons. Set the 4 uni-head rivets tying the F-757 gussets to F-705 as well...this may have been pre-mature? Shaped the F-695 fwd gussets (main longeron to firewall stiffener) to a good fit. Drilled the gussets and then match drilled the longerons and stiffener. Scuffed, MEK-wiped, and primed the F-695's edges and faying surfaces.
