Brief Description: Assemble rudder and brake pedals
Bolted up rudder and painted brake pedals, and brake cylinders. For now, the cotter pins are NOT installed. Thought about substituting a single round rod and/or using oilite bushings for the brake pedals as others have done. In the end, went bone stock. (Least weight!). The Matco cylinders have strong spring returns incorporated, and the travel of mechanism is pretty smooth. Good landing and taxi technique means the brake pedals will hardly ever be used, so the pivot points don't need triple-self-centering ball bearings!
