Charlotte and I continued installing the interior and carpet that we purchased from Flightline Interiors in WI. We installed the upper panels above the arm rest on each side. The panels consist of a woven gray material that is backed with foam that can be glued to the skin. Our panels above the arm rest were specially constructed with a 2" hole that holds the Aveo Swivel lights. These lights are a red/white LED swivel light that we will use to illuminate a knee board and the instrument panel. The on/off switch is a touch switch built into the light and required no wiring of a seperate switch. The light can be changed from white to red with just a touch as well as changing the intensity by touch. We also positioned the carpet on top of foam panels under the rudder pedals. These are easily removable if the inspector wants them removed.
We have an FAA safety inspector from the San Antonio FSDO scheduled for the airworthiness inspection on 30 Sep 2013. Hope it goes as scheduled!
Panel above the arm rest with an Aveo swivel light installed.
