Brief Description: trim system wiring,Rudder stops
The trim system wiring has now been completed,trim indicator wired and both control stick trim switches connected into the system and the speed control relay mounted and wired.Had a small glitch with the aft control sticks isolate s/w on the panel,after reversing the wires all fine.Functional system check carried out and all operating correctly. Set the rudder stops to 30* + - 3*
