Brief Description: Cover lower surface of left hand wing
Final inspection of inside wing prior to applying fabric.Lower sheet applied and glued minto position.Note the inboard end of wing,i decided to finish the fabric this wayfor a better result..this photo shows incomplete,I intend to cut a airfoil shape peice of fabris and lay it over the entire end to seal all the fabricedge
