KENNETH'S WEB SITE
Date:  3-21-2010
Number of Hours:  9.00
Brief Description:  cowling
filled firewall to cowl gap with superfill, sanded to flush. shaped the inlets and spinner ring to match the prop spinner using a rasp and sandpaper. Re-drilled the attach screws at the fwd section of the cowl and added blind nuts. began sanding entire cowling in prep for pin hole filling.
superfill
superfill
right side gaps
right side gaps
