Finally, back at it again. Even if only for a short time tonight. My friend Dennis fixed my error some time ago by removing the pins out of the wrong end of the connector so this part was easy. Re-assemble the wire into the correct side of the connector and push into the servo bracket. Image two is the actuator arm that I have prepped, deburred, etc. I will work on it tomorrow and probably finish it tomorrow.
