LES'S WEB SITE
Date:  4-24-2007
Number of Hours:  0.00
Manual Reference:  25-3.3.a
Brief Description:  Trim F-1004A Lower Flange
To trim the flange I used thge Dremel tool with a high sped bit. I marked roughly how much material was to be removed, trimmed some and then test fitted the kanding gear mount. The pictures below give a much better idea as to how the gear mounts fit on the forward bulkhead than the plans.
