KDaniels
Date:  3-8-2015
Number of Hours:  3.00
Manual Reference:  None
Brief Description:  Trim Tab Control Fairings
I started work today by takling the rear curvature of the fairings. By fiddling around a bit I found I could create a tuck in the metal using the fluting pliers, and then drive the tuck flat with a ball=pean hammer. This effectively shrunk the metal as needed. I then found I could use my wood forms, a body hammer and a steel dolly to smooth out the roughened metal and get a nice smooth curve.
The result is shown in Image 1.
Using this technique, I was able to get both flanges to closely match each other, and achiever the shape I wanted. Comparing the fairings against the trim tab control horns suggests I should have pleny of clearance when everything is assembled.
In the Images, I have trimmed the flanges to 5/8 inch, but I have not yet drilled them for mounting.
Total weight of the two fairings and mounting hardware is approx 57 grams. (2 oz)
I am going to use the same screws and nut plates (4 per fairing) that are used to secure the E-616 cover plates to the elevator. This will allow the fairings to removed if needed (eg to inspect the control linkage).
Fairing curvature
Fairing curvature
Right Fairing
Right Fairing
Left Fairing
Left Fairing
