5/2/19 4.4 Hours Hung door on aircraft. Tape marked rear and bottom bubble. Removed door to table. Trimmed bubble using a Dremel cut-off wheel. Sanded edges. Back onto aircraft. Norma would hold door open while I sanded areas to get the clearence into jamb. Got a good fit. Removed door to table and back drilled pilot holes through bubble.
5/3/19 Received ACK E-04 ELT from ASS 3.1 Hours Removed bubble from frame. Up drilled holes in door frame and guessets to #20. Placed bubble back on frame and up drilled holes in plastic to 3/16". Located centerr latch back plate and clamped into place. Marked center of latch hole and drilled. Installed latch to hold back plate in place and backed drilled through back plate into square tube to #20 for AS5 rivets.
5/4/19 Towed acft to local EAA chapter pancake breakfast. Lots of questionns and "good work"s. 2.5 Hours Cleaned plastic then riveted left bubble to frame. Temp installed latch on right door then marked location for strike plate.
