6/16/19 5.0 Hours Spliced the 24AWG PTT wires with Raychem tiny little butt connectors. Shrink wraped the bundle, Reinstalled padded clamp for transponder antenna cable and another cable support against firewall. More under dash wiring housekeeping. Tried a radio check with ground control and they said I was weak but maybe too many buildings in line-of-sight
6/17//19 4.2 Hours Finished up for awhile the wiring under dash. Removed rivets on bottom inboard trailing edge of left wing in prep for installing access door.
6/18/19 3.3 Hours Continued with lleft wing trailing edge access door. Sandwitched parts togeather, back drillled rivet holes and clecoed. Marked for opening. Removed parts. Used a step drill for the corners then a fly-cuttter to take out most of the center piece then snips to rough cut center.
