Brief Description: Seats, fuel line leak test, rear wubdiws
8/24/19 4.3 Hours Removed windshield. Dressed a few holes in top window trim. Checked to see that I had put castle nuts and cotter pins in lts that hold brake pedels and brake arms together. I hadn't so did that. Drilled holes and riveted the 6 snaps on each seat pan to hold seat cushins in place.
8/25/19 2.0 Hours Reinstalled right seat pan and put cushions in place. Spent some time looking and thinking about the bungees to keep the eleavator cables apart and to even out the tension.
8/26/19 3.3 Hours Modified a radiator test kit from Harbor Freight for fuel line leak test. Plugged right fuel line. Conected tester to left line and pumped up to 5# PSI. After two hours, still holding pressure. Will let test run overningt. Preped the two rear window. Sanded edges. Up drilled factory pilot holes to 1/8" with plastic drill then to 9/32" with standard drill. Clecoed windows into place. Made a stop for elevator mass balance. Not sure I'll use it.
