3/11/19 2.0 Hours Ran wire from both wing roots to below pilot and passenger seats for fue level sensors. Wires will join up with EMS wires at that point Drilled three holes each in upper foreward fuselage stiffners for zip ties to secure wiring. Temp zip tied wire bundles in place to check routing and need for edging.
3/12/19 3.1 Hours. Can work much longer when not freezing pa-tookus off. Removed temp zip ties from wiring bundles, Enlarged zip tie holes to accept larger/stronger ties. Deburred holes and edge of angels. Installed spiral wrap onto bundles and added grommet edging to angles where bundles would rub. Tie wraped bundles into place. Butt spliced fuel sensor wires together and shrink wraped.
