2/26/19 2.5 Hours Moved the ADAHRS mount inboard 3 inches to make it more accesable.Temp mounted ADAHRS to see if couldd be serviced in new location. Seems OK. Drilled 3/8" hole for temperature probe 4 inches towards centerline from end of ADAHRS. Removed second rivet from bottom of left most L angle of baggage bulkhead for another padded champ for comm coax.
2/27/19 Picked-up custom RG-400 coax cables from local avionics shop. 2.0 Hours Removed temperature probe and shortened wires using butt splices per Dynon. Reinstalled. Routed RG-400 coax cables to comm, ADSB- in and xponder antennas.
2/28/19 2.0 Hours Put xponder in bracket and tried different rountings for cabel. Will have to have xponder cabel redone, too long and wrong connector on xponder end (need TNC). Removed fuel hose from thru firewall fitting in prep for fuel flow sensor. What a chore. Cut short (3 1/2") for conection. Added 90 deg fitting to output of flow sensor. Wil leak test prior to installing as it will be next to impossable to check after installation.
