2/15/19 2.4 Hours Drilled 1/2" hole in left baggage foor for ADSB-out antenna. At Paul's suggestion, riveted 2" diamerter doubler into place. Added terminals to fuel flow sensor and fuel pressure. Marked possible location for comm antenna on roof 3' from GPS antenna.
2/16/19 1.7 Hours Drilled 1/2" hole below passanger seat for transponder antenna. Prep 2" doubler. Couldn't locate transponder antenna (turned out it was at home) so could not complete installation. Have to do some more thinking about location of comm antenna. Might add access hole to left side of baggage area bulkhead or on fuselage side to get at preferred location 3' from GPS antenna.
2/19/19 1.3 Hours Temp mounted transponder antenna and then back drilled through bottom of fuselage. Deburred holes then riveted into place. Mounted antenna. Removed orginal fuel tee behind pilot seat and put in new one that has longer arms. Checked mag switch to asure they were right side up. One was. One wasn't. Marked both for future install.
