3/20/20 2.1 Hours Safetyed the remaining six exhaust springs. Deburred the Rotax oil tank. Added two liters of Sport 4 plus 4 oil to oil tank. Filled the coolant system. Zip tied a few more wires.
3/21/20 2.1 Hours Added the oil tank vent line running down to below the fuselage bottom. Safetyed wired the four bolts of the lower nose gear block.
3/23/20 2.2 Hours Removed oil filter off engine. Had to loosen raidator top brackets to be able to get filter out of its location between radiator, radiator hose and #2 cyli.. Have not done it yet but it think the lower brackets will also have to loosened to get the oil filled filter back into place. Safety wired the two steel bungee nuts. Safety wired the quick drain on bottom of oil tank Connected starter cable to starter solinoid and checked voltage at starter end of cable when starter button pushed (not connected to starter). Connected starter cable to starter.
