1/2/20 2.2 Hours Dressed right lower edge of top cowling third camloc back to make a better fit. Replaced the two AN3 bolts onright OB flaperon with drilled AN3s, castle nuts and cotter pins. Tightened misc nuts and clamps ii engine compartment. Dropped-off cowling and spinner at autobody shop for painting.
1/3/20 1.7 Hours With Norma holding the light, replaced the un-drilled AN3 bolts on the remaining (6) flaperon arms with drilled AN3s and castle nuts and cotter pins.
1/4/20 Wind 44 with gust to 68 MPH at airport 2.0 Hours Hod Paul over after the monthly EAA meeting. We installed the bolts for the flaperon control spacer. Pual suggested rotating hose clamp on radiator to clear shield. Did that. Used file on both under wing fuel vents to make bottom of tube 45 deg to air flow.
