12/27/18 1.2 Hours Forgot to put the anti-seize lube on the exhaust joints so took apart, lubed and re-assembled. It can be done by one person, at least the second time.
12/28/18 1.2 Hours Cut notch in heat shroud flange so shroud would fit around engine mount. Reinstalled oil tank and oil lines onto tank Those are real icicles on hangar door. Brrrrrr!
12/30/18 1.4 Hours Snugged the engine mount bolts and added cotter pins. Lookiing at fuel line routing into wing. After looking at a video about wing mounting, thinking of adding an access panel to inboard trailing edge. Temp forecast for tomorrow is 7 to 9 degrees. Thinking I won't be working on aircraft.
