11/21/18 1.1 Hours Drilled hole in instrument panel mockup for flap switch. Need to be accurate because throttle support bracket is very close. Mostly thought about placement of other switches and went to look at aother acft.
11/23/18 1.7 Hours Removed old instrument panel in prep for new arriving next week. Cut piece of hose and installed for oil line sheath at oil pump were line runs over mounting bold. More thought on electrical componet placement. Different drawings have things in different places.
11/25/18 2.1 Hours Over laid old instrument panel on the new and marked locations of throttle and choke and drilled holes. Located location for starter switch and trim indicator.
