Brief Description: Flaperon control covers, windows
1/21/20 2.1 Hours Riveted lower forward skin tab to cage. Riveted both flaperon control covers.
1/22/20 1.5 Hours Cleaned the two rear windows with "Plane Perfext Eyes Outside" then riveted with the aluminum A4 rivets. Drilled out the left door latch stricker plate and bent down the corner some more. Re--installed striker plate one set of holes futher back.
1/23/20 3.0 Hours Moved the right door latch striker plate back one set of holes same as left one yesterday; Worked on the left wing tip plastic pieces.
