10/16/19 2.7 Hours Clamped then drilled door cylinder onto left door. Assembled door cylinder. Mounted door onto aircraft. Again used bar clamp to compress cylinder to mark location fo door jam fitting, Drilled and clecoed. Door opens a little more than right one. Good for tall me. Applied three cork strips to top of both fuel tanks. Deburred top wing skins that go over fuel tanks. Clecoed right skin into place.
10/17/19 3.5 Hours Clecoed left top wing skin over the fuel. Cleaned door cylinders fittings then applied primer. In afternoon, final painted the cylinder fittings. Attached fuel sensor wire to sensor. Riveted fuel sensor ground wires to ribs.
10/18/19 2.2 Hours Riveted fuel tank top skins. Sure go through the A5s in a hurry. Spent time positioning sample registration number on side of aircraft.
