4/23/20 2.0 Hours Removed spinner and cowling. Disconnected fuel line to mechanical engine fuel pump and capped fuel pump inlet. Started to set up flaperon to be able to install controll stops. Will have to tweak control rods to get them even.
4/24/20 2.2 Hours Adjusted flaperon alignment by turning right conector one and a half turns. Set deflectiond to 13 degs up and down then marked location for control stops. It will take two people to get the stops in correct place and drilled
4/25/0 2.3 Hours Preped stab plastic ends starting with 220 grit then 400. Wiped chean. Added cotter pin to one of the nut on the elevator bell crank. Cleaned skin surfaces.
