2/27/20 2.0 Hours Attached strobe lights to wing tips. Added lugs to black ground wires of strobes. Attached ground wire made yesterday to wing strobe cable Shrink wraped all new conections. With help of hangar neighbor, put nose wheel on lazy susan turn table.
2/28/20 2.1 Hours With Norma holding the wing tip with the strobe attached, I crimped the wiires to the shieled cable. After each one, I would would tlurn on the switch on the power panel to verfly that it worked. Did this for both wings and at the end, turned on both nav and strobes. Strobes flashed together just like they should. Riveted the three ground wires to outboard spar. Clecoed righ forward t tip into place and zip tied wires.
2/29/20 3.5 Hours Worked on left aft wing tip. Got it clecoed into place then did right aft wing tip. As posted in others logs, thely are a pain. Did another test of electrical by turning on switches. Everthing worked OK.
