11/20/19 2.0 Hours Up drilled the rest of the flaperon wing arms to 1/4" and the flaperon mounting stubs to 3/16". Installed the pivot bushings in six arms (already in other two).
11/21/19 1.3 Hours Tried some metal polish to get the mouse urine etch off right inboard flaperon. Did not work. Used sample canloc kit from Dallas to detirmine which camlocs to use on cowl. The samples were not long enough (only went to a #4). Ordered a couple of #5s amd #6s from ASS.
11/22/19 1.7 Hours Up drilled the pilot holes in upper cowl to 1/4" for camloc studs. Riveted oil door hinge to cowl. Installed oil door Dzus fastener spring with flush A5 rivets.
