11/18/19 2.5 Hours Marked right outboard counter weight mounting tabs, pilot drilled and up drilled. Mounted right outboard flaferon back on wing. Up drilled outboard arm to 1/4" and stub to 3/16". Inserted bushing, washers and bolt with nut
11/19/19 Read the zenith.aero fourm about the flaperon pivots. 3.3 Hours Continue with right outboard flaperon Up drilled inboard arm to 1/4" and stub to 3/16". Inserted bushing, washers and bolt with nut Flaperon moves up and down freely. Watch out for weight hanging down. Hurts like the devil when you smash your head into it. Moved the other three flaperons to work table one by one. Marked, drilled and clecoed counter weights to each. Once all are ready to install, will up drill spar line rivet holes to A5.
