9/24/19 4.0 Hours Borrowed dimpler from Paul. Dimpled 20 inboard A3 rivet holes and lugs on 20 nut plates. Up drilled screw holes to 13/64". Riveted nut plates on both inboard wing access holes.
9/25/19 4.0 Hours Dimpled 20 outboard A3 rivet holes and lugs on 20 nut plates. Up drilled screw holes to 13/64". Riveted nut plates on both outboard wing access holes.
9/26/19 4.0 Houea Spent the four hours getting the left lower strut fittting to go onto the fuselage tab. The slot in the strut fitting was not uniform and had to be filed/sanded on one side. I want a snug fit but not forced.
