Brief Description: Re-set prop, center console, N number
5/17/20 1.6 Hours Re-set propeller to 10 1/2 degs.
5/18/20 1.4 Hours Screwed center console into place
5/19/20 2.2 Hours Had to take center console apart after I realized that I had not tightened parking brake cable into place. Screwed center console back together again.
5/20/20 Received new registration numbers from AeroGraphics. 1.9 Hours Applied the new registration numbers. Tested the parking brake. Worked good just trying to move the plane by hand. Will have to do a more in depth test next engine run.
