Brief Description: Controls, seat area, mic/phones, windows
5/26/19 6.0 Hours Tried lebeny seven different combination of the flaperon and elevator horns. Each had a problem of something hitting something else. Went back to the configuation that Paul and I agreed upon. Painted top coats on mic/phone plug box. Afixed "passenger warning" to right of map box. Clamped in place to alow glue to set overnight. Cut, drilled and deburred four L angle stiffeners for seat bottom areas. Added grommet edging to right aft angle and sprial wrap to wiring. Got the right one finished.
5/27/19 4.6 Hours Riveted the two L angles to bottom of left seat. Installed the two sets of mic/phone jacks into plug box. Verified no short with ohm meter. Clecoed box into place. Borrowed a head set to see that jacks had clearance. Installed CR2 3V battery in ELT alert. Put windshield on and started to get top window to fit. Trimmed a little on windshield upper corners.
5/28/19 3.1 Hours Screwed mic/phone box to center ccnsole. Installed the supplied Ray Allen grips with PPT to control sticks. Spliced right side PTT wires harness. Zip-tied wires to bottom of control tube.
