Jay's Cruzer
Date:  3-28-2019
Number of Hours:  8.90
Brief Description:  Instrument bulkhead/panel
3/26/19
2.9 Hourss
Cut hole in instrument panel for trim rocker switch. Drilled another hole to right for curict breaker. Up drilled holes for #6 mounting screws. Removed instrument bulkhead from aircraft. Clecoed bulkhead and panel together. Marked bulkhead for the trim switch and new CB location. Drilled hole for breaker and cut hole for trim switch.
3/27/19
3.3 Hours
Using butt splices and heat shrink, spliced 6" (4) power and ground extentions onto trim switch and trim indicator. Put power panel into place and marked holes for mounting screws. Drilled holes through instrument panel. Clecoed panel and bulkhead back to gether. Holes did not line up. I swear. It seem that you can clamp two pieces together, drill a hole through both, take them apart and then try to put them together again and no way the holes will line up. Aaarg! Will have to snowman the holes some.
3/28/19
Received parts from ASS.
2.7 Hours
Filed right side of powerr panel opening and mounting holes to get all mounting holes to line up. Spliced 6" extention onto trim indicator dimmer lead.
Shaping up
Shaping up
