Jay's Cruzer
Date:  11-8-2018
Number of Hours:  8.90
Brief Description:  Brake and cabin heat
11/6/18
3.3 Hours
Riveted cabin heat cable bracket together. Riveted brake cable bracket to left center console side panel. Clecoed cabin heat valve to firewall then located spot for cable bracket. Drilled and clecoed bracket into place. Ran push-pull cable to butterfly valve and tried movement. Did not like. Re-located cable lead on bracket. OK now.
11/7/18
3.2 Hours
Back drilled firewall through baffle then removed. Riveted cabin heat butterfly valve and cable bracked to inside firewall. Cut 18 inches from cable to better see how it fit. Will have to cut about 6 inches more once I figure were the control knob is located. Next plane (ho, ho) the butterfly valve hole should be an inch higher so baffle rivets will clear motor mount on other side of firewall
11/8/18
Received nuts and bolts from ASS. Ice off eaves. Very loud when it falls.
2.4 Hours
Temp bolted parking break valve into place. Added fuel line with fire sleave between firewall gascolator and electric fuel pump Bolted fuel pump into place. Revised layout on center console.
