5/24/20 2.3 Hours Re-torqued prop clamp bolts. Safety wired the prop mounting bolts. Added chaffing tape to engine mount where I had wires and lines zip tied to frame. Got 8 out of 10 done
5/25/20 .7 Hour Finished adding chaff tape tape to engine mount. Added marks on coolant overflow bottle at half and three quarters.
5/26/20 2.6 Hours Opened the inspection panels. Installed the cross member in bottom of fuselage. Armed ELT and tested.
5/27/20 3.0 fHours Paul did a pre-inspection for me. Scheduled DAR is 5/30/20. He found 19 issues, anything from loose jam nuts to things rubbing on each other. Corrections takes from a few seconds to a whole lot longer.
