2/17/20 2.4 Hours Placed a 1 1/2" L angle with a cleco across top of fuselage to support skin while fitting lower fin skin. Fin skin on and off several times. Got it to fit. Will leave L angle support in place while back and up drilling lower skin.
2/18/20 2.7 Hous Back drilled and up drilled all holes in fin lower skin. Removed and deburred. Clecoed back into placce and riveted starting with the A4s into upper skin then with A5s along L angle on top of fuselage. Removed fuselage support L angle and replaced rivet with an A5. Top of fuselage is flat.
2/19/20 Too clold at ariport (3F). Work at home on wing tips and flaperon counter weights.
