2/8/20 2.6 Hours Norma applied Cortec to the elevator up stop parts. Pilot drilled, up drilled then riveted with 4 A4s stop into place. Verified 28 deg +/- 2 deg. Inserted eye bolt in very aft bulkhead and tightened for zip ties to secure trim motor wiring. Tight working space. Tested trim to verfly working OK.
2/9/20 2.7 Hours Relocated felx gromett to protect trim wire from inside to stab. Trimed flange of right rear wing tip. Cleaned flaperon counter weights. Marked location on vert fin for Zenith stickers. Sanded wing tips.
2/10/20 1.7 Hours Applied the Zenith stickers from AircraftStickers.con to vertical tail prior to attaching tail to aircraft. Trimmed the lower edge of tail skin for better fit on stabilizer. Think it needs some more. It is still rubbing on stab skin.
