7/19/19 Received bolts from ASS and rear fuselage/fin plates from Zenith 4.0 Hours Drilled pilot holes fin L angle iand then a couble nto stabilizer top skin and clecoed. Tried fin in place for fit. Looks OK. Marked location of L angle onto inside of fin skin. Removed fin and transfered angle location to outside of skin. Drilled pilot holes in skin for L angle attachment. Replaced AN5 bolts in pulley assemblies. Riveted lower pulley into place. Put fin back on acft.
7/20/19 2.0 Hours Back drilled through fin skin pilot holes in stab L angle and clecoed as I went. Started on fin nose piece. Used a piece of long L angle on leading edge of fin to project where nose piece would meet top of fuselage. CuFt-outs for leading edge of stab have to enlarged a fair amount. Started trimming.
7/21/19 4.4Hours Fin nose piece on and off a bunch of tiimes. Fileing. Final fitting with Norma holding the very springy nose piece in place. Got a good fit and back drilled a few holes through the nose piece into fin and clecoed
