3/24/20 3.1 Hours Un-bolted lower radiator mount to allow raidiator to move forward and down to allow space to put oil filter on. Filled oil filter with oil and reattached to engine. Added oil to input line. Read service instruction, SI-912-018R2 "Purging of Lubricution System" dated 4/16/18. Added more oil to tank. Reattached radiator to engine.
3/26/20 2.0 Hours Read the instructions for the WarpDrive prop the started to assemble. Have to have the prop so I can purge the oil system (turn engine up to 60 revs).
3/27/20 2.0 Hours Worked on spinner faceplate. Drilled 5/8" holes to be able to get a socket wrench on the WarpDrive inner clamping bolts. Filed a flat spot on the six fender washers so that they would not interfear wrench access. I had asked Paul what was his prop pitch. He called back to say it was 13 deg, a starting point.
