2/23/20 3.0 Hours Painted left wing tip. Greased rudder pin with white lithium grease. Norma held rudder in place while I inserted pin. Added safety wire to hold pin in place. Attached rudder cables with drilled AN3 bolts and castle nuts. Tried rudder pedels for feel. Could not find the rudder stops, Z1-6. Will order. Made template for the 20 deg left/right deflection.
2/24/20 Ordered rudder stops from Zenith. 1.0 Hour Snow. Stayed home and painted right wing tip.
2/26/20 1.4 Hours Reattached strobe light mounting hardware to the forward wing tips. Made groundinng wire for the strobe cable. Added flutes to forward edge of forward top skin.
