1/30/20 2.0 Hours Updated Dynon data base. Worked on the two windshield holddown clips. Have to locate shorter #10 washerhead screws.
1/31/20 1.3 Hours Removed windshield to bench. Removed protective film from inside and Norma cleaned inside and glareshield vinyal. Put windshield back on aircraft. Clecoed into place. Screwed lower retainer clips into place
2/1/20 3.3 Hours Riveted the two flaperon end cap into place. Paul stopped by to fill the crevices between the fore and aft wing tip pieces with an epoxy, micro balloons, cotton flock mix. Started to screw the windshield into place
