1/15/20 1.2 Hours Continued working on the plastic wing tips. One thing is obvious: the wing leading edge and the plastic tip leading edge do not exactly match. Checked builder's fourm. WOW. Lot of others also.
1/16/20 2.1 Hours Finished riveting forward top skin. Moved windshield to bench. Trimmed a little more on glareshield vinyal. Started to glue with RTV silicone windshield weather seal in place. Not enough clamps. Have to do in two stages.
1/17/20 1.4 Hours Glued more of the seal to the windshield. One more day to go around the corner. Tried a bar clamp on thie right forward plastic wing tip to see if that would pull it into the leading edge skin. I think it'll work with just a small space between tip and skin on lower part of curve.
