12/17/19 2.8 Hours Up drilled the lower cowl camloc receptacle holes. Missing something. The studs barely have a lip Removed left front engine (#2 cyl) exhaust pipe. Using a Dremel cut-off wheel, shortned left front engine mount 3/8" to give more room for radiator hose. Ordered camloc grometts, studs and split rings fromm ASS.
12/18/19 1.2 Hours Dressed the cut left foreward egnine mountl. Exhaust pipe on and off a few times to get the hose re-connected in the correct place.
12/19/19 1.9 Hours Up drilled the six holes each on each of the four flaperon counter weight mounting tabs to A5 rivet size. Cut two more polyethylene washers for the right flaperon hinge pivot.
