11/12/19 No work yesterday because of the cold. 2.6 Hour Double clamped flaperon pivots and updrilled to 5/32'". Will wait until I get hinge bushings (and control spacers) from Zenith to updrill to 1/4" Pilot drilled the two root hinge pins.
11/13/19 1.5 Hours Removed cowling and trimmed the lower right cowl with Dremel cut-off wheel. Put back on plane to check clearance. It is OK. Putzed around with the flaperons.
11/14/19 1.0 Hour More putzing with flaperons. Temp mounted flaperon counter weights to see what rivets I need to remove.(one each top and bottom all four weights).
