10/14/19 2.7 Hours Tourqued upper strut fittings to 60 lt-lbs. Installed fuel tanks into each wing. Drilled hole in second rib to rivet fuel sensor ground wire. Installed 45 deg barbed fuel fitting into tanks with sealant. Cut six cork strips for top of tanks and clamped them to work table trying to get some of curl out.
10/15/19 4.1 Hours Drilled pilot holes in the four steel door cylinder fittings. Clamped the door mount to the right door and drilled, Up drilling to A5S. Assembled cylinder. Mounted right door to aircraft.. Proped open door to where I though it should be. Marked location on door jam for fuselage mount. Drilled and clecoed. Tried to close door. Ran out of cylinder travel. Oops. Un-clecoed lower end. Closed door. Used bar clamp to compress cylinder and marked jam for new location. Drilled new holes and clecoed. Tried door and it closed OK. The design needs longer cylinders to let the door open more fully.
