8/30/19 3.2 Hours Riveted left side baggage floor into place. Glued windshield spacers together.
8/31/19 4.2 Hours Attached things to inside firewall. ADS-B screwed. Heat vent riveted. Engine monitor screwed with stand-off spacers. Rearranged some wires.
9/1/19 3.3 Hours Norma spent the entire time cleaning the bottom of the fuselage. Added cotter pin to lower elevator attachment. I added washers and cotter pins to nose wheel steeering rods on rudder pedals. Riveted in right side throttle pass through on firewall. Will redo. Cut a slot instead of a slit in fireproof material. Riveted right side back baqggage piece into place. Ran out of A4 rivets.
