8/15/19 3.1 Hours Shotened the four #8 GPS antenna screw by about 5mm. Starting to work on windshield again. Trimmed some more on top outboard ends.
8/16/19 4.7 Hours Put top window (TW) in place and drilled pilot holes and clecoed. Drilled a few (4) pilot holes in top window trim, clamped into place and back drilled into TW and clecoed. Removed windowshield and re-installed to see if it could be done with top window in place. It can. Finished pilot holes and back drill of TW.
8/17/19 4.0 Hours Up drilled back edge of top window to #10 size screws. Removed and deburred all. Added strip of vinal tape to top of ribs. Re-installed top window and riveted sides. Will have to get longer #10 washerhead screws. The 10R9s that came with kit are too short to show 1 to 2 threads.
