Jay's Cruzer
Date:  8-13-2019
Number of Hours:  10.20
Brief Description:  Nav wires, top window
8/11/19
3.2 Hours
Zip tied nav/strobe and fuel sender wires to left fuel line in channel behind left door. Added cork strip to top, foreward edge of fuselage skin where top window will rest. Placed top window in place and marked aft edge of window for trimming. Trimed window with Dremel cut-off wheel. Test fit right baggage lower floor and right side tunnel console piece to see if they can be riveted into place and still add upright channel cover later. Look like they can.
8/12/19
3.7 Hours
Zip tied ELT monitor cable to top of fuel line running from right to left in baggage area. Riveted lower baggage floor and tunnel side pieces together. Clecoed them into place to verify that channel cover could be added later. Had to trim top of channel covers to clear fuel lines and wires comming from wings. Marked outter edge of top window for trimming
8/13/19
3.3 Hours
Riveted lower baggage floor and side of center tunnel into place. Trimmed side of top window. Norma removed excess anti-corrosion paint in cabin.
Top window cork
Top window cork
Right baggage floor
Right baggage floor
Trim top window
Trim top window
