Jay's Cruzer
Date:  7-9-2019
Number of Hours:  7.50
Brief Description:  Stabalizer
7/7/19
2.0 Hours
Clecoed eleavator to stab. Bananced elevator. Used six of thick weights and one thin one. applied Cortec to elevator weight arm. Deburred weights and bolted into place.
7/8/19
2.0 Hours
Attached inside fuel lines to elbows at fuselage wing root with double hose clampst. Used Soaring Aviation crimp tool to make the #4 grounding cable for engine to firewall.
7/9/19
3.5 Hours
Attached cable tie mount to elevator spar for trim motor cable. Drilled out and removed one of stab plastic tips. Trial fit stab on plane. Looks like that it will not take too much adjustment Shims at attach points will be needed.
Fuel lines clamped
Fuel lines clamped
Trim cable
Trim cable
