4/1/19 2.4 Hours Continued to twek map box to fit. Finally got it. Riveted door hing into place. Clecoed box to panel/bulkhead. Reinstalled panel/bulkhead back into plane.
4/2/19 2.7 Hhours Removed panel/bilkhead. Added 4 anchor nut plates around the map box (no A3 rivets yet). Added two new mounting locations half way betwee corners of panel/bulkhead and first pre-drilled holes (the pre-drilled corner holes leave no room between them and the steel tube cabin cage). Panel/bulkhead back into aircraft.
4/3/19 1.6 Cut 4 pieces of 1/4" fuel line for wiring protectors. Placed wind screen onto aircraft. Will defenitely have read/watch some blogs/videos.
