2/20/19 1.9 Hours Re-installed mag switches correct side up. Started the layout and pilot hole drilling of MyKitAirplane SQIO access hole on left side of fuselage for access to comm and ELT antennas.
2/22/19 2.3 Hours Temp assembled fuel pressure sensor with new "street tee" onto fuel pump. Drilled 5/8" holes in corners of new access hole. Used fly-cutter to cut 4" hole then my new offset snips to cut stright sides to corner holes. Installed back plate and up drilled to A4 size rivets. Deburred all then riveted back plate into place. I think it will workout great to access antennas on top.
